Brake question. 2014 Chevy Suburban 1500 4x4
Old Apr 20, 2020 | 2:19 AM
Orlando Santiago's Avatar
Default Brake question. 2014 Chevy Suburban 1500 4x4
I did a new install brakes, rotors, calipers. The problem I am having is that I bleed system lines for air. I can build up presure when vehicle is off. When it is on I can get pedal to build and give it a second for booster to register then press brake and goes right to the floor. So basically does the test for abs on modual have to be done to purge system for air. Any ideas also welcome. DIY guy.
Old Apr 24, 2020 | 4:35 AM
ChiefChicagoLimo's Avatar
Default Break Booster
Hi Orlando,
we have had similar problems with some of our Suburban Limos
Turned our to be a Break Booster issue. 2 were under warranty, rest were like $680 to fix. We always recommend extended warranty.
Jan 25, 2020 10:01 AM
magnum 49
May 18, 2015 7:18 AM
Babar
Nov 7, 2006 2:56 AM
