Need Help
Need Help
hello everyone my name is Jesse and im new to this forum.
Currently im working on a 1973 corvette and i just had a engine put together and i hoping some would be able to look at he engine spec and let me know what they think of this. Its a 454 Chevy big block
Here are the specs of the engine
JRE prepped Chevy 2 bolt main block, bored to 4.280
Ground smooth, stamped #44, painted JRE silver
JRE prepped Chevy 4.00 cast steel crank .010/.010
Clevite P series bearings .010 undersize
7/16 dot rods with ARP 7/16 bolts
TRW forged pistons,.030 over, 29.4cc dome, 10.42-1 compression
Hastings moly rings, gapped at .022 top, .020 second
Crower hydraulic roller cam
lobe lift intake .369 x 1.7 ratio rocker .627 valve lift
exhaust .372 x 1.7 ratio rocker .632 valve lift
duration @ .050 intake 244
exhaust 256
intake centerline 104
Comp Cams retro-fit hydraulic roller lifters
Comp Cams pushrods
Comp Cams Springs, retainers, locks
Chevy 074 Aluminum heads mildly ported with a 116cc chamber
Eaton stainless 2.250 intake valve
Eaton stainless 1.880 exhaust valve
Harland Sharp 1.7 roller rockers
Holley Strip Dominator intake manifold #300-5
Crane billet true roller timing chain
Melling HV oil pump and pickup
Speed Pro steel oil pump driveshaft
GM Corvette 8 quart oil pan with baffles
Fel Pro head gaskets .039 thick
Fel Pro 1 piece oil pan gasket
MRG intake gaskets
ARP head studs
JRE oil pan studs/nuts
JRE stainless timing chain bolts
JRE stainless intake manifold bolts
GM external balancer
Hays billet steel flywheel
thank you in advace
exhaust 256
Comp Cams pushrods
MRG intake gaskets
ARP head studs
thank you in advace
Welcome to the forum.
Sounds like you have a very strong player in that engine. Beware that now you will be able to find the next weakest point in the drivetrain if you're not careful.
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
