Wont shift to 3rd
Wont shift to 3rd
Hey everyone I'm new on here so be nice.... after rebuilding the front suspension on my 2007 Silverado for the 3rd time in 10 years I gutted the interior and put in a new one inch thick rubber mat on the floor. I took off of work in the gas pedal stuck while I was going about 65 to 70 miles an hour. As I approached the rear end of a dump truck have to break but sort of panicked and threw it in neutral for a few sections with tact over six grand. I was able to pull the pedal free with both feet and push it back in gear slow down and check everything out didn't realize that It wont shift to 3rd gear but the engine and everything else seems fine. I checked all the fuses drain the transmission replacement fluid screen and change the 2 3 shift sensor but it still won't shift I had this problem a couple years ago but it was a fuse suggestions?
Welcome to the forum.
You need to post your info in the truck section of the forum. Thus is the welcome new member section
You can copy and paste it.
rshaner15
October 19th, 2020 11:14 AM
Robert Chenard
December 10th, 2019 10:20 AM
