North Eastern ME, NH, VT, MA, RI, CT, NJ, NY, PA
gmc5599 Chevrolet 2010 Impala "engine hot/turn off ac"
Old Jul 10, 2016 | 9:06 PM
GMC5599's Avatar
Default gmc5599 Chevrolet 2010 Impala "engine hot/turn off ac"
Currently, I am having a problem with "engine hot/ turn off ac" I have had the thermostat replaced twice. The reset button reset and told to drive. Same problem. Sensor replaced. Same problem. Now I am told maybe electrical. This has been going on for months. In addition to the thermostat and sensor, in the past year I have had the blend door actuator replaced, rack and pinion steering replaced, power steering pump replaced. I am bleeding money into this car.
Old Jul 11, 2016 | 6:18 AM
It could also be a partially clogged radiator. A good back flush could help. The engine block might also need to be flushed.
Old Jul 11, 2016 | 7:58 AM
cleveland63b's Avatar
sounds like you have an overheating issue that needs diagnosed, when does it happen?
