Car won't start
Old Jul 17, 2017 | 2:42 PM
  #11
kevinkpk's Avatar
Originally Posted by Dan Enghoffer
No. When the key is off nothing happens. When the key is on and you touch it the starter cranks but doesn't stop after the car is started.
So, with pulling the wire off, the starter still cranks?
Old Jul 17, 2017 | 2:51 PM
  #12
kevinkpk's Avatar
Circuit should be from battery +, through ignition spring position switch, nuetral switch, starter solenoid on the small S terminal. The other small terminal marked R is for a resistor cut down from full battery to electrnoic ignition coil, if applicable. The kicker on this is the replaced column, that has the saftey switch, and the ignition switch.
Old Jul 18, 2017 | 5:31 AM
  #13
Dan Enghoffer's Avatar
No when I pull the wire the starter does not crank.
Old Jul 18, 2017 | 5:33 AM
  #14
The ignition switch on the 68 nova is on the dash. But your right. I can't find the safety switch anywhere. Sounds odd huh.
