Got an early 60’s Powerglide with reverse problem
Old Mar 20, 2021 | 11:39 AM
Yaahoos's Avatar
Default Got an early 60’s Powerglide with reverse problem
I have an early 60s powerglide transmission that locks in park, works in reverse, but when I put it in neutral, drive, or low, it stays in reverse? I even attempted to remove the shifting linkage and do it by hand with the car raised and it still does the same.
obviously I am thinking it is internal, but what exactly internal could it be? If anyone has any expertise in this area I would appreciate the help. Hopefully I can do this fix “in vehicle”.
Old Mar 20, 2021 | 12:35 PM
kevinkpk's Avatar
Is park, and reverse next to each other? I had a 57 Bel Air that reverse was all the way down. If it is only going park, or reverse, pull the pan, and check the internal linkage. Is the shifter actually moving into drive?
chevra
Jul 7, 2014 7:59 PM
BigBlock'Burban
Oct 5, 2011 3:53 AM
prplhaze181
May 8, 2011 7:20 PM
five20too
May 10, 2008 11:05 PM
Kev
Jul 9, 2006 12:23 AM
