I need help identifying an engine purchased on CL
Old Mar 16, 2021 | 9:56 AM
Raz Cue's Avatar
Default I need help identifying an engine purchased on CL
Gonna drop this into a 64 Chevy II Nova sedan. The seller didn't know anything more than it is a 250. Any info you guys can decipher would be greatly appreciated
Old Mar 16, 2021 | 7:05 PM
Paul Garrison's Avatar
Default Re serial #
F0206A second picture. Serial numbers are stamped in not casting numbers. Not sure what date law went into affect. 1950? But adding serial number was to reduce auto theft by make engines traceable to original car. But manufacturers also used number to give dealer and repair shops a way to know exactly what engine package it is. But as far as swap should work. With some minor modifications. Same block different crankshaft larger bore. And other minor internal differences. Also think it been a long time since I worked on those motors. But you will have to use newer model carb. Unless you manufacturer an adapter for older carb.
good luck
Old school tuner.
Old Mar 16, 2021 | 9:33 PM
Raz Cue's Avatar
Thanks man!
Old Mar 16, 2021 | 9:34 PM
oilcanhenry's Avatar
Yeah, on the 250, its stamped on the block, above the fuel pump.
VanKo
Jan 10, 2021 10:17 PM
GoldBullet
Aug 4, 2020 7:03 PM
Tin-man
May 13, 2019 1:35 AM
Cargirl2017
Dec 19, 2016 7:20 PM
