Surging problem
Old Oct 3, 2011 | 5:20 PM
wrrn73's Avatar
Default Surging problem
On my 72 Nova 350 2 bl. carb. I have noticed a surging when going down the road at a steady speed. I recently converted my distributor from points to electronic by changing the pickup plate in my old dist. I was told it could be the vacuum advance. I unpluged this and didn't make much difference if any. Any ideas?
Old Oct 3, 2011 | 5:29 PM
kevinkpk's Avatar
Sounds like a vacuum leak. Could be the advance, other than the distributor what else has changed? Does it stutter at idle?
Old Oct 3, 2011 | 7:04 PM
wrrn73's Avatar
When I did the distributor I also had the transmission serviced. That is all that was done. It does fine at idle and hard acceleration.
Old Oct 3, 2011 | 9:11 PM
kevinkpk's Avatar
Check the tranny modulator valve for a vacuum leak. Idles fine is hard to diagnose as a vacuum leak, but look at what has changed go from there.
Supercharged Biscuit
Mar 3, 2013 1:21 PM
wrrn73
Nova & Chevy II
Nov 1, 2011 8:51 PM
Miracle
Sonic (Aveo)
Aug 11, 2007 2:20 AM
kan_man69
May 2, 2006 10:30 AM
aberg7039
Mar 30, 2005 12:42 PM
