$150 Cash Back on Venture TEC Rack by Putco at CARiD!
Former Sponsor
https://www.carid.com/putco/
There is no need to describe the value of a durable and functional bed rack for a truck owner. If you're on the market for this kind of upgrade for your Chevy Silverado, make sure to look at Putco's Venture TEC Modular Cargo System. Constructed using aluminum-extruded tubing, it has a distinct look as well as unparalleled functionality.
It can be easily mounted to any truck in two ways - using stake pocket mounts on trucks with stake pockets and using OEM hardware on a rail system for non-stake pocket trucks. It is also compatible with tonneau covers so that you can have both wet and dry storage.
Update your truck with this high-quality Venture TEC Rack today and get $150 back in your pocket. The offer is valid until May 15, 2020. Please check the PDF form to get your reward: https://images.carid.com/putco/promo...ebate-form.pdf
Putco® - Venture TEC Rack
https://www.carid.com/putco/venture-tec-rack.html
Features:
- Lightweight and strong all 6061 T6 Aluminum construction
- Pass through channel for in-stanchion wire routing
- CNC 7 axis bending for exact vehicle cab contour
- TEC channels for accessory modifications
- No Drill Installation stake pocket
- High Impact durable black powder coat finish
- 500lb tie-down strength
- Compatible with all Putco TEC accessories (Tie Downs, Hand Grips, Light Bars)
- Designed, engineered and manufactured in the USA by PUTCO INC.
- Putco exclusive patent pending extrusion tube
- Works with all modern tonneau covers
carid
February 8th, 2019 8:02 AM
carid
December 12th, 2018 8:11 AM
carid
June 7th, 2018 9:06 AM
carid
June 27th, 2017 9:07 AM
