1983 Chevy Celebrity Part ID ?
Old Apr 10, 2011 | 7:11 PM
Pinky1352's Avatar
Question 1983 Chevy Celebrity Part ID ?
Hello,
I need assistance identifying and replacing a part for the above car. From the shop manual, it it identified as a 4 cyl, 2.5L (Pontiac engine type by VIN ID), fuel injected engine. On the vacuum label on the car, the part says it is a purge control valve, but in the Haynes manual the closest picture of the part labels it as a EFE/TVS switch. It is located on the side of the engine closest to the firewall and has an end that is obviously some sort of coolant temp sensor. The other, plastic end has two nipples that attach to vacuum lines, one of which definitely runs to the purge control canister and the other terminates somewhere under the EGR valve. The only markings on the part I can find read "27 HRD and EGR and C"
Thank you in advance for your assistance!
Old Apr 11, 2011 | 3:54 PM
Pinky1352's Avatar
Identified the part, a local Chevy dealer was helpful even tho they couldn't get it. It is a Thermal Vacuum valve, part #14003932, and this particular one was used on 83-84 Celebrities and Citations.
If anyone ever needs one this place has them
1984 CHEVROLET CITATION II 2.8L 173 cubic inch V6 2BBL (X) OHV Electrical-Switch & Relay : Ported Vacuum Switch Auto Parts
celebrityrestore
Sep 18, 2015 12:59 PM
Colgate41
Oct 7, 2010 9:32 AM
Kalispellbob
Jun 15, 2009 8:16 PM
CRFrizzell
Feb 24, 2007 12:36 AM
sullivan_joshua
Feb 10, 2007 9:02 PM
