1990 k1500 brake light
Old Aug 18, 2014 | 9:11 AM
khali20830's Avatar
Default 1990 k1500 brake light
Hey I have a 1990 k1500. My brake light will not turn off. I brought it to a shop and they told me both wheel cylinders where blown. So I bought all new parts and put them in, with a brake flush. My light is still on, anyone know a possibility as to why?
Old Aug 19, 2014 | 1:58 PM
SWHouston's Avatar
Your problem is electrical, not mechanical.
If that brake light will flash when you turn your turn signal to that side, it's your Brake Switch.
If it won't, it still may be your Brake Switch, but, may also include the Turn Signal Switch.
I'd change out the Brake Switch first.
Old Aug 19, 2014 | 10:07 PM
Rednucleus's Avatar
Brake light on the dash or the tail light?
Old Aug 22, 2014 | 12:08 PM
khali20830's Avatar
Thanks both of you for replying. I didnt specifically say whether it was my tail lights or my dash. It is my dash. I had blown wheel cylinders, replaced both and redid both side brakes in the back. I can finally stop correctly, however my light on the dash has not gone off. It goes dim and goes away from time to time now, but it still comes on more than not.
Old Aug 23, 2014 | 12:37 PM
Farmer Jon's Avatar
I had the same problem with my 90. Brake light was on when I bought it over 10 years ago. Replaced the wheel cylinders as you did. Put new brakes and rotors on the front. One steel brake line rusted through so I replaced all of them. I sold it to a buddy and its still on. I have no idea why.
Old Aug 23, 2014 | 8:27 PM
Rednucleus's Avatar
I have a 93 Suburban. The chilton's has a section on needing to "center the switch" after brake work to get the light off. It talks about holding a pin open on the combination valve and bleeding the rear brakes, then applying heavy pressure to the pedal to center the switch and turn the light off. It's in the section titled Combination Valve.
opie4487
14
Jan 18, 2014 12:10 PM
beckya99
Jul 12, 2011 12:29 PM
sodell
Apr 22, 2011 9:33 PM
firefighter51378
K5 Blazer
May 9, 2010 1:38 PM
opie4487
Mar 14, 2007 11:19 PM
