1993 5.7 into a 1997 gmc
Old May 30, 2019 | 9:46 AM
Hayden Rinlee's Avatar
Default 1993 5.7 into a 1997 gmc
Have a 93 350 I want to put into my 97 gmc. Is there any way to make it work with the computer or can I make it carbureted. Really want to use the 93 motor cause it only has 1500 miles and the 97 threw a rod
Old May 30, 2019 | 10:21 AM
Irish_alley's Avatar
I'm here for the party
was the motor in the 97 a 350? im not sure but you might be able to swap the top half (use the 93 block/pistons/crank and use the 97 top half heads/intake.) and then you could use the computer for the 97. i would wait till someone else confirms this
Old May 30, 2019 | 10:35 AM
Yes it was a 350 I just wasn’t sure if those heads would match up
