1996 chevy c1500 5.0l wont start no power
Old Apr 2, 2017 | 11:10 AM
steve1993's Avatar
Default 1996 chevy c1500 5.0l wont start no power
just bought this truck and it ran great for a few weeks, was told fuel pump was just replaced and it ran perfect, I drove it one day and it started to have no power it would bog out after half throttle and would take forever to start up it kept getting worse and eventually wont start at all, I ran seafoam in the gas tank and it ran awesome again and even turned over quicker and restore power, now that the seafoam is gone its back to the same problem, thought i would change the fuel filter and looked underneath and there was no fuel filter on the truck so i ended up putting a new fuel filter in. Still having the same problems, does not want to start up it just cranks over, sometimes if it gets started it sounds like it catches a couple times then slowly fires up. any ideas?? thank you
Old Apr 2, 2017 | 11:12 AM
steve1993's Avatar
i wanted to add to this but when it does start up it idles fine. If you try to rev the motor it does not have the power like it should. And when you drive you can only tap the gas any kinda of pressure on the gas pedal makes it bog down
