1998 C3500 Stock Dual Positive Battery cable terminals faulty.
I have 2 battery cables (stock from the factory) running from the positive side of the battery and to each fuse box (one in the engine compartment one inside the cab). My problem is the two cable connection at the battery. They are alway becoming loose and after the truck is running for thirty minutes it is really dragging and will eventually start. Anyone else see this and have a solution?
Thank you,
Kirk
Thank you,
Kirk
