94 buick lesabre 3.8 liter high idle
Old Aug 24, 2010 | 7:04 PM
TLW64's Avatar
Default 94 buick lesabre 3.8 liter high idle
friends 94 lesabre has a high idle problem. code read quad driver failure. cleared and no codes came back vehicle will start and then go high idle, when you shut engine off you may have to wait 10 to 20 minutes before engine will restart. suspected bad idle air control valve and replaced that part but problem still there . engine had a heavy vacuum sound checked for loose vacuum hoses and found none. any help would be greatly appreciated
Old Aug 25, 2010 | 1:25 PM
TLW64's Avatar
just want to let everybody know that i replaced the ecm on the vehicle and that solved the problem , it also solved the no speedometer problem the car had .
mudrider
Aug 3, 2022 9:25 PM
in2pro
Dec 25, 2020 11:34 PM
stanman
Apr 3, 2013 11:35 AM
Outlander 2004
May 21, 2011 10:37 AM
