Does not stay running
Old Jan 4, 2016 | 3:49 PM
John Johnson's Avatar
Default Does not stay running
I have a 1983 Chevy van g20 aviator passenger conversion van has a 305 engine and it runs and idles good as soon as I start to drive it a mile or two it dies and doesn't start for half hour to an hour I've change the spark plugs and the wires and did a thorough cleaning of the carburetor I cannot figure out what's wrong with this thing please somebody help
Old Jan 4, 2016 | 6:12 PM
chevy55's Avatar
could be your ignition module thats crapping out.ignition modules were a know failure on the older ignition systems.it could be something else.if i were you check for spark right away when it happens at least it will be a place to start.hope this helps.
Old Jan 20, 2016 | 3:06 PM
Johnny 99's Avatar
I'm going to second the ignition module opinion. It's not that expensive of a fix and it does sound like it should do the trick.
Old Jan 20, 2016 | 3:18 PM
chevy55's Avatar
Make sure to put the dialectric grease on the back of the module that comes with it.if you don,t it will shorten the life of the ignition module.
