Misfire, backfireing, loosing power 5.7 K1500
Old Apr 4, 2014 | 12:08 PM
Lilpig's Avatar
Default Misfire, backfireing, loosing power 5.7 K1500
I have a 93 K1500 4x4 with a 5.7. 160,000 miles on it.
For the last few months its been running rough. I thought I had water in the gas so I have been running heat and Lucas through it. It lessoned but never went away. As I would go down the road it seemed to cut out for a second and then would run fine. It seemed to do this more going up hills.
Then the last 2 weeks it started running really bad. Backfiring, loosing power up hills, shaking, cutting out for a second multiple times.
Today I changed the cap, roter and all the plugs. There was no change after doing this,m still ran the same. I changed the wires a year ago and still look fine.
When I turn the key to the on postion the fuel pump kicks in and sounds normal. Next I pushed the gas pedal to the floor and cranked the moter over for about 30 seconds and it sounded fine. I am not getting any check engine lights and have not gotten any since this started happening months ago.
Any thougths as to what to do next?
Old Apr 6, 2014 | 3:32 PM
Lilpig's Avatar
UPDATE
I just did a fuel pressure test and I have 11psi when running. From what I understand with a throttlebody injector it should be between 11-13psi.
Old Apr 6, 2014 | 4:25 PM
Lilpig's Avatar
I think I solved the problem. I changed all the plug wires and it seems to be running fine. It has it's power back when I hit the gas. It still looses power when it shifts through the gears. That may be from it being low on gas. I'll fill it up tomorrow.
UH60sSuck
14
Sep 16, 2017 9:25 AM
crispy4
Apr 6, 2014 2:05 PM
Malibu2001LS
Mar 17, 2013 4:54 PM
rallrusw
Aug 31, 2011 11:08 PM
Vampiretooth
May 16, 2009 3:00 PM
