rubber burning smell, 88 Celebrity
Old Dec 16, 2007 | 10:32 PM
spinner074's Avatar
Default rubber burning smell, 88 Celebrity
I noticed a rubber burning smell only when the heat is on and it only smells under the hood and not coming inside the vents in the car, anybody know why I smell that? The car is a 1988 Chevrolet Celebrity 2.8V6 w/AC. it doesn't get to a burning ( as in seeing any smoke ) situation and it was like this last winter and I didn't smell it all summer, Any ides would help, thanks in advance.......John
Old Dec 17, 2007 | 6:05 AM
astroDZak's Avatar
Default RE: rubber burning smell, 88 Celebrity
The A/C pump will run during the time you have defrosters going so I am wondering if there may be a problem there.
Might be belt slippage caused by a lose belt or a compressor going bad.
Easiest way to determine if this is the problem would be to unplug the electrical connection from the compressor
Old Dec 17, 2007 | 9:00 AM
spinner074's Avatar
thanks for the reply I'll try that, but when heat is on compressor is not engaed?, only when defroster on, not sure if I had the defroster on when I smelled it, any other ideas if its not compressor,? would belt dressing help? My car has a spring loaded tension terpintine beltsystem.
tentenmarschel
Sep 1, 2012 6:44 PM
shannoni
May 4, 2011 1:48 AM
97lumy
Jan 15, 2009 8:32 PM
Hardin Thicke
Feb 27, 2007 2:44 PM
