SSR Key fob
Old Jul 6, 2009 | 4:16 AM
WayneP's Avatar
Exclamation
All
I am look for information that will guide me through re-programing the key fob for my 2006 SSR, the local dealer which I purchased the fob from at 3 times the price in the US is now wanting another $100 to program it.
Regards
Wayne
your comments are appericated, thanks
Last edited by EvansBlue; Jul 6, 2009 at 11:17 PM. Reason: Merged double post. Use the edit function for adding afterthoughts.
Old Jul 6, 2009 | 6:59 PM
shawnvw's Avatar
Banned
Sorry bud, it needs to be done at the dealer, unless you know someone with a Tech2
Remote Control Door Lock Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
  1. [*]
kcarberry
Jan 24, 2014 5:37 PM
chevykicksbut
Oct 23, 2010 12:32 AM
2manychevys
Jan 13, 2010 2:59 PM
freight shaker
Jan 24, 2008 6:26 PM
HP15
Oct 31, 2006 12:25 AM
