Transmission Dipstick tube
Old Sep 1, 2018 | 7:02 PM
Chuck TieDye's Avatar
Default Transmission Dipstick tube
Hi. I'm working on a 1984 Chevy G30 Hi cube van that sat a very long time. Right now I need to change the transmission dipstick tube. (TH400 trans) The original goes all the way to up under the hood, and is around 60 inches long.
Here's my question: Would it matter if I replace it with a much shorter tube (and stick)? I would have to check the level from under the doghouse, but that's no big deal. I ask because I've searched hard and I cant find an original replacement part. Should I just go with a short one that the parts house says it will fit my vehicle?
Thanks for your input
Chuck
1984 Chevy G30 Hi-cube 350 gas engine
Old Sep 1, 2018 | 8:30 PM
Twscarp's Avatar
Hi, try car-part.com, a used parts company.
Old Sep 1, 2018 | 9:23 PM
I"ll go take a look right now. Thanks.
Old Sep 2, 2018 | 7:49 AM
If you go with the shorter one, are you going to be able to reach it easily to check your fluid level?
Old Sep 2, 2018 | 1:30 PM
Yes, no problem there. This vehicle has a van front end; I will have to open the doghouse (engine cover) to reach the dipstick, but that's not something I will need to do often.
What I am hearing is that the original long tube is for convenience sake and that the short one will be accurate if I dont mind having to open the doghouse.
Old Sep 2, 2018 | 1:37 PM
That's a decision only you can make. If you are ok with removing the cover to check the oil, then go for it.
