S-10 & Blazer 1982-2005
1991 S10 Tires
Old Mar 18, 2009 | 12:21 AM
CTY's Avatar
CTY
Question 1991 S10 Tires
My '91 S10/Tahoe Blazer 6cyl 4x4 has factory (litteraly - 38000 orig) tires. I think they are 205 75 R15.
Anyway, what is the biggest size I can put on before I get a rubbing prob?
Old Mar 18, 2009 | 10:01 AM
EvansBlue's Avatar
255/70R15 probably the biggest you can get without rubbing. Honestly, I'd go back with 235/75R15
You can actually do the math an measure off how big the tire will be.
255(width-mm)/70(% of width)R15(rim size)
Width Profile Rim
You have a 205/75R15, Which is 205mm wide, 154 mm tall.
If you get a 235/75R15, The tire will be 2 cm wider and 2.2 cm taller.
A 255/70R15 will be 4cm wider than stock, 2.4 cm taller.
JHarris8732
Nov 10, 2011 11:25 AM
ddover
Mar 18, 2008 4:28 PM
bradahl
Feb 29, 2008 4:14 PM
tmk1990
Jan 7, 2008 10:07 AM
mile51
May 10, 2006 1:48 PM
