S-10 & Blazer 1982-2005
1993S 10 4l60e transmission not shifting
Old Jan 9, 2016 | 6:40 PM
vincent52100's Avatar
Default 1993S 10 4l60e transmission not shifting
I have a problem with my transmission not shifting. Originally I had a code 28 and a hard shift between 1st and 2nd. Transmission shop said 28 was Trans oil pressure switch. I replaced the switch. I also replaced the A and B solenoids, the 3/2 down shift solenoid and the wiring harness. Now it doesn't want to shift. It won't shift down when you accel hard. You can only feel it shift once in a while. Shifting manually doesn't work. I've pulled the pan and see nothing obvious. What in the world have I messed up? Thanks for any help. I have a headache from beating my head against the wall!
Old Jan 11, 2016 | 1:17 PM
Well, it was a dumb problem. Got to remember that when your lying on your back looking up things can be backwards. Had the solenoid in the PWM slot instead of the 3/2 downshift slot. Works fine now.
