S-10 & Blazer 1982-2005
1994 Chevy s10 zr2 4.3, idles rough when warm
Old Jun 18, 2019 | 9:39 PM
  #21
charrisps6's Avatar
Kinda wondering if i have a computer issue now that my initial reading is so low, all my other sensors signal wires were .50
Old Jun 18, 2019 | 10:15 PM
  #22
Irish_alley's Avatar
I'm here for the party
my understand is if you disconnect the sensor it will read a default setting of .5 and should run the same as when its cold. when it cuts off do you have to let it cool down before it can restart? do you still have a catalytic converter on it? i dont want to say "bad ECM" as i dont believe theres a way to test it. but if you knew someone that had one you could swap it out. another friend i talk to says if nothing else make sense on these TBIs then replace the ECM but i dont want to say that unless youve swapped it and the newer one works
Old Jun 18, 2019 | 10:18 PM
  #23
charrisps6's Avatar
It will start right back up but just idle like crap and my catalytic is off
Old Jun 18, 2019 | 10:20 PM
  #24
i updated that post as you were replying to this one
Old Jun 18, 2019 | 10:41 PM
  #25
charrisps6's Avatar
I have an O2 coming tomorrow and if this doesn’t work then my next step is to swap out the ECM because the signal wire isn’t getting the correct voltage
Old Jun 18, 2019 | 10:42 PM
  #26
could it be a poor connection at the ECM?
Old Jun 18, 2019 | 10:47 PM
  #27
charrisps6's Avatar
Connection? As in where all the wires are plugged in?
Old Jun 19, 2019 | 12:50 AM
  #28
yes, take it apart inspect and put it back together
Old Jun 19, 2019 | 10:20 PM
  #29
charrisps6's Avatar
I looked at the wires for my O2 sensor connector and they are all black, so I took out the ECM and I only saw one black wire going to it, just my luck the clips that hold the connector pins in are missing so I couldn't get it out. I'm going to try again tomorrow to see if I can ohm that wire out to see if its a bad connection in the actual signal wire. so basically I've narrowed down, with the key turned on the wire is reading a (.17) so I need to figure out why I am not getting (.5 v) to the wire. I know that sounds simple but it has taken me a month of every day looking and finding to get to this point.
Old Jun 20, 2019 | 10:30 PM
  #30
charrisps6's Avatar
My O2 sensor was bad and I replaced it out and it’s operating perfect, I tested it with a voltmeter to be sure. Still didn’t fix my issue, surging idle until it eventually chokes itself out.
