S-10 & Blazer 1982-2005
1994 S10 Blazer Electronic 4WD Problem
Old Dec 30, 2010 | 3:16 PM
SegueSeven's Avatar
Default 1994 S10 Blazer Electronic 4WD Problem
Something is wrong with the 4WD. Will engage in neutral to 4WD Lo which means the vaccum is probably working but 4WD Hi will not engage. I have tried resetting the control module as described in the owners manual. The switch used to shift works fine. i am thinking it is the accuator, the transfer case motor or the module itself. let me know anything if you can.
Old Mar 25, 2011 | 9:34 PM
disty's Avatar
my 99 jimmy does the same thing.heres what i have found out . the problem is in the harness that plugs into the 4X4 control module.apparently water gets in somehow and corrodes some pins in the plug causing your problem.module is located under kick panel on passengers side footwell. hope this helps
brewknife
Mar 8, 2014 5:16 PM
chadsr
Jan 27, 2011 7:54 AM
darmour88
Dec 15, 2010 6:04 PM
#1DEER1I
Feb 12, 2008 10:44 AM
