S-10 & Blazer 1982-2005
1995 chevy s-10 hvac and high idle vacuum leak fix
Old Mar 31, 2019 | 4:38 PM
Sean Kramber's Avatar
Default 1995 chevy s-10 hvac and high idle vacuum leak fix
I love working on my truck and learning new things. I was having problems with HVAC vent selection and a high idle. I fixed it with a check valve. I did have to ask a repair shop what the problem might be and they told me to look at the check valve.
Old Mar 31, 2019 | 11:11 PM
Irish_alley's Avatar
I'm here for the party
????????????????? this make no sense at all. auto and manual tans both would run the same rpms:speed. no matter if it had a vacuum leak or not. if they had a higher rpm the speed would also be higher. watching this video is a total waist of time as you dont fix anything. i want to know why you have fuel line thats too big being used as vacuum line, i would be more into thinking your map sensor being routed to other things is more of an issue than anything. but im not sure how the s10 works i know on my 94 c1500 its not that way.
Old May 29, 2019 | 12:49 PM
charlie2sods's Avatar
my issue with the high idle was the gasket under the throttle body was defective
Old May 30, 2019 | 1:25 AM
oilcanhenry's Avatar
Glad you solved your issue. Haven't seen one of those vacuum storage ***** in years.
