S-10 & Blazer 1982-2005
1995 s10 2.2L fuel pump wont kick on
Old Feb 27, 2018 | 8:47 AM
Nickbalazs_'s Avatar
Default 1995 s10 2.2L fuel pump wont kick on
So i bought this 95 s10 for 650 and i thought it just needed a fuel pump. turns out it was a mistake.. so i put in the new fuel pump turned the ignition no pump, so i wired a test wire from the postitive terminal on the battrey to the fuel pump and it turned on cranked the truck over does not start. so i had my buddie spray starting fluid into the intake and it starts right up but when i stop it turns off. so i check put a new fuel pressure switch in not the problem switched the relays around still does not switch the pump on. im lost i dont know what to do anymore other than see get into the wiring harness and look for torn/cut wires. any ideas would be appreciated thanks.
