S-10 & Blazer 1982-2005
1996 Blazer revs after start-up
Old Jan 17, 2011 | 4:33 PM
jamesf94's Avatar
Question 1996 Blazer revs after start-up
I have a 1996 Chevy Blazer, 4.3L V6. Sometimes after start up it will rev up to 2500 RPMs. Recently, it stalled after this when I didn't put it into gear right away. Any ideas?
Old Jan 18, 2011 | 9:14 PM
jamesf94's Avatar
Anyone have any ideas? I cleaned up my IAC value, but that didnt do anything.
Old Jan 19, 2011 | 4:10 PM
lynnboy021's Avatar
how did you clean your iac?
Old Jan 20, 2011 | 1:10 PM
jamesf94's Avatar
i removed it and sprayed it with throttle body cleaner. then after it dried, i put it back in.
Old Jan 21, 2011 | 9:21 PM
lynnboy021's Avatar
ya you realy should not do that but my fod was the same thing and i took out the throttle body and cleaned it with throttle body cleaner and cleaned the MAF then installed a new air filter and bingo did the trick. if that does not work then it could maybe be your TPS. in the morning befor starting up remove the TPS plug and then start it up see what happens (warning your check engine light is going to go on but when you plug it back in it will go away) if unplugging the tps did not work then just clean the tb and maf.
Chevyman1989
Dec 31, 2013 1:52 PM
Dark Volker
14
Sep 15, 2010 11:21 PM
ranger0001
Mar 27, 2009 6:06 PM
betmerick
Mar 16, 2008 12:38 PM
gdore28
Nov 21, 2006 11:19 PM
