S-10 & Blazer 1982-2005
1997 Chevy S-10 2.2L engine troubles
Old Jan 21, 2011 | 6:58 AM
Jmeronek's Avatar
Default 1997 Chevy S-10 2.2L engine troubles
I blew my timing chain just recently and put a new gone on. When I tried to start it, it runs as if I am missing a cylinder and the exhaust is a bluish and smells heavily of gas. It will not start unless I put my foot on the gas. It will not run at idle sometimes, other times it will idle fluctuating between 900 & 1200 rpm. 2000+ rpm the engine runs smooth but pops every so often. Still blue exhaust though.
I have checked to ensure plug wires are still connected, all of the connectors are still plugged in, and hoses connected. I took it all apart to make sure I got the timing right and didn't accidently go a tooth out of phase. Everything looks as it should. Could you give me an idea as to what to check or do next?
Old Jan 21, 2011 | 1:47 PM
stock s10's Avatar
You Blew the timing chain? Did you pull the head to check if any of the valves got bent in the process? Any time the timing goes out of sync it is a good idea to check for internal damage.
Old Jan 21, 2011 | 2:09 PM
Jmeronek's Avatar
Was trying to avoid that part. Working in a garage with no heat and 10-20°f weather. They're calling for -30 windchill tonight. Oh well, will have to look.
Thanks!
Any other ideas anyone?
Old Jan 24, 2011 | 7:44 PM
2wd-K5's Avatar
a compression test will tell you quickly if u have a problem there, instead of pulling the head
also when working on it, why not get it to opperating temp? makes it nice to work on in cold weather
Old Jan 25, 2011 | 11:15 AM
Jmeronek's Avatar
Took OBDII tester to it and it is indicating a fault in the camshaft pos sens and low signal in camshaft pos sens. Going to test and see if it's bad, but need to know where this bugger is on my 2.2L I4 engine. I know it needs to be inline with the camshaft somewhere, but Haynes does not show where it is on this engine model.
Old Jan 25, 2011 | 2:31 PM
stock s10's Avatar
I couldn't find an exact location but i did find a reference to it being on the back of the block. Hope this helps a little.
sdoyle586
Mar 23, 2011 2:30 AM
uproar1
Mar 8, 2010 3:53 PM
mallard
K5 Blazer
Dec 1, 2009 10:33 AM
nsuln
Feb 16, 2007 5:27 PM
Varhalla
Mar 7, 2006 1:20 PM
