S-10 & Blazer 1982-2005
1997 chevy s10 2.2 litre manuel transmission
Old Jun 14, 2021 | 8:26 AM
Smoke1xx's Avatar
Default 1997 chevy s10 2.2 litre manuel transmission
My 1997 Chevy S10 2.2 man transmission died while driving. Now wont start wont crank no noise no dash lights the gauges are all stuck right where they were when it died except the temperature gauge its on zero the speedometer is on 48 mph please help I can't figure this out. Update I've pulled a wire from positive battery terminal to s terminal on the starter and the engine turns over but still won't start. I also removed the fuel filter and put a tee in with my fuel pressure gauge and turned the engine over and the key to start position and no fuel pressure and can't hear the fuel pump come on snd prime
Old Jun 15, 2021 | 4:17 AM
oilcanhenry's Avatar
If it's the original fuel pump, it's done well for a 24-year-old vehicle. Nothing lasts forever, so if it is the fuel pump, you will need to replace it.
Old Jun 22, 2021 | 9:58 AM
hogbiker's Avatar
Since this came on all @ once, I'd start checking the fuse clusters, both in the cab and under the hood...good luck
Firebird65
Apr 19, 2014 1:45 PM
mramsey
Dec 7, 2013 4:04 PM
ripashocker
Feb 24, 2011 4:44 PM
mastermosley
Dec 20, 2007 12:11 PM
bauschone
Apr 24, 2007 12:45 AM
