S-10 & Blazer 1982-2005
2.0 engine valve adjustments?
Old Feb 8, 2013 | 3:08 PM
Mosinguy's Avatar
Default 2.0 engine valve adjustments?
What are the correct clearances for the exhaust and intake valves on my 2.0? I am fixing up an 1984 S10 and am having a slight ticking noise. It's either a lifter or valves not adjusted right.
Old Feb 8, 2013 | 3:38 PM
kevinkpk's Avatar
I'm probably going to get slammed on this, but here is how I adjust valve trains for 40 years.
Valve cover off (back in the day we had valve covers on that were cut out) running, gently run the stud nut on the rocker arm slightly till the tick is no more.
Otherwise I going to guess around .010"
Old Feb 9, 2013 | 10:09 AM
Mosinguy's Avatar
Is that the clearance for both valves? Or with that method am I just adjusting until the noise goes away?
Old Feb 10, 2013 | 2:03 PM
Mosinguy's Avatar
Anyone else?
TahoeMatt
Feb 28, 2013 8:13 PM
83_Caprice_Classic
Sep 21, 2010 2:12 PM
supersam
Cobalt
May 20, 2007 12:30 PM
