S-10 & Blazer 1982-2005
2000 chevy blazer LT 2wd will try to start it self with the key on the acc postion.
Old Feb 4, 2017 | 5:49 AM
richsa72's Avatar
Default 2000 chevy blazer LT 2wd will try to start it self with the key on the acc postion.
The truck will start to turn over by it self. Like someone is bumping the key. Only happens when the key is on the acc postion. It takes it like around 15 mins or a little less. We're should I start to look for a short if that is the problem
Old Feb 4, 2017 | 9:32 AM
a faulty ignition switch.
with the key in accessory, check for voltage coming out of the ignition switch to the wires that feed the starter solenoid.
