S-10 & Blazer 1982-2005
2000 s10 ext cab v6
Old Aug 6, 2010 | 6:06 AM
carolinacurl's Avatar
Unhappy 2000 s10 ext cab v6
One day, temp. went to 230, next day knocking, took straight to mechanic, bad engine and no water in radiator.
My questions are: I am a woman of this vehicle. Would it be worth to put another motor in it or better for me to sell it as is? I need something to drive.
Also if keeping it is the way to go, what engine should I put in it? new or rebuilt?
I am on a budget but want to drive a vehicle that needs to last me for some time.
Also what years engines can I look for?
I enjoyed driving that little truck. Body is decent, it is white, it has the rubber floor throughout, and leather interior. I am sick over this! What would you do????
Old Aug 6, 2010 | 7:35 AM
maxxman04's Avatar
rebuilt engine for this should be less than $2k, i would think. which is about what you might pay for another vehicle that's remotely reliable. the v6 is a very common motor. easy to find. you may be able to find a good used motor too. check local wrecking yards and local craigslist. i think the decision is all up to you. if you really like the truck, put a motor in it. or look around and see what it might cost for the same truck. good luck
Old Aug 10, 2010 | 4:28 PM
Default Cross Reference Engines
Where can I find out what engines will fit in my 2000 V6 4.3 S10? I have decided to put a wrecked vehicle engine in mine.
Old Aug 10, 2010 | 5:26 PM
maxxman04's Avatar
96-02 chevy s10, full size trucks, gmc jimmy/sonoma, full size truck all had the 4.3 as an option.
Old Aug 26, 2010 | 2:51 PM
Red face 4.3 vortec motor 'installed'
Hi maxxman04, the motor has been installed! Got one locally from the nearest wrecking yard, cost $600 + tax = $646 + had to use my pan from my motor which I was going to have to anyway. Mechanic installed, labor + parts = $750. Total = around $1400...whew!
Mechanic said motor skipping, 3rd cylinder, but "should" clear up as it is driven. I'm letting hubby drive it, he has a 'long' commute. If it does not clear up, then will have to use the injector from my old motor. I think that is right I'm not engine fluent )
But that is where I'm at so far, I just wanted to let you know since you were so helpful.
dpainter68
Dec 7, 2012 10:22 AM
bagNdrag
May 29, 2011 6:49 PM
2000 zx3
Feb 22, 2008 1:53 PM
mikewaterskis
22
Oct 10, 2007 8:47 PM
