S-10 & Blazer 1982-2005
Installing an AMP w/ existing fuse block
Old Aug 11, 2010 | 12:52 AM
chevman711's Avatar
Default Installing an AMP w/ existing fuse block
Hello all,
This is my first post, so here goes...<O</O
I have a 02 S-10 and I want to install an aftermarket amplifier. It’s a small amp that only requires a 20AMP fuse. I noticed (on the door jam fuse block) there’s an unused fuse socket labeled “AMPF 25A” however, on close inspection there appears to be a metal “pin” on one side of the fuse socket, the other is left blank. (my truck didnt come with an amplifier) If I wanted to tap into this fuse socket for my amplifier what would I have to do? Is it possible to install a pin in the fuse block and run a wire?
<O</O
What are your thoughts? thanks for tanking the time to read/post!
Old Aug 12, 2010 | 12:10 AM
chevman711's Avatar
Ok, using the stock fuse block may not be the best idea...
I’m installing a Boss CX250 amplifier (20A) and a Cobra CPI480 400Watt PWR Inverter (approx. 40A) I’m considering running a 6 gauge cable just under 10’ to my cab, then branch off some 8 gauge feeders to the amp (about 9’) and the inverter (about 5’). Will my amp pickup any interference from the inverter? And how could I wire up my Inverter to only run when the “ignition is hot”?<O></O>
Thanks
Old Aug 26, 2010 | 5:46 PM
BigAlsBro's Avatar
Thanks
Buy an inline fuse wire, 20 amp. fuse & clamp an "o" clamp on the end hook it directly to the (pos) battery via the antenna hole on the firewall.
ill4na8na2
Apr 7, 2024 6:50 PM
Tom Miks
Jan 27, 2012 5:23 PM
10_LTZ_2500HD
Apr 19, 2010 7:05 PM
aalexander
Jan 14, 2010 7:03 PM
