S-10 & Blazer 1982-2005
MIL after tuneup, can't get codes
Old Aug 26, 2010 | 5:06 PM
jaymaynard's Avatar
Default MIL after tuneup, can't get codes
I have a 1995 Blazer 4x4 4-door, VIN code W 4.3L V6, with 209K miles on it. Yesterday, I replaced the spark plugs, plug wires, distributor cap (with side towers), and rotor; everything's new AC Delco parts except the plugs, which are E3 Diamondfires. Now it's running rough and smelling rich, like a cylinder isn't firing. It gave me a MIL (service engine soon light), too, flashing on the dash like something's wrong (duh!).
I pulled out my AutoXray EzScan 6000 to try to pull the code so I could see what was wrong. My Blazer's got an OBD-II computer in it (yellow cable from the AutoXray, set to 1996 year model, communicates; set to 1995, with either the yellow or blue cables, says it's not communicating). I ran the scan. It told me that the MIL is on, but that there are no codes stored.
I reseated all the connections at the spark plugs, and wiggled the wires, but the condition doesn't change. How do I go about finding out what's wrong? Preferably without burning the hell out of my hand on the exhaust manifold?
Old Aug 26, 2010 | 6:50 PM
If you smell it running rich, it would be my guess that the plug wires are crossed somewhere and the cylinders are not firing correctly and the un-ignited fuel is being sent out the exhaust...double check and recheck the wires at the cap and the plugs
Old Aug 27, 2010 | 7:32 PM
jaymaynard's Avatar
I thought I'd double-checked, but checked again, and sure enough, the wires to 4 and 6 were reversed at the distributor. Swapped them, things are good. Still wish I knew why I couldn't pull the codes, though.
Old Aug 27, 2010 | 7:45 PM
glad you found it, it could be because it was coming up as a mis-fire and it just didn't know what code to put...
malibuboo
Aug 22, 2015 10:25 AM
Nipper
Jul 8, 2012 4:49 PM
gosman
May 30, 2012 11:02 AM
RobertShumaker
Astro
Nov 2, 2011 3:10 PM
jackcountytruck
Apr 7, 2011 8:56 AM
