1998 Suburban Tuneup Woes
Old Jul 8, 2012 | 12:23 AM
Nipper's Avatar
Default 1998 Suburban Tuneup Woes
Hello, new to this forum. Great to see all the help being provided. I installed new ignition wires, Autolite double platinum plugs, a new distributor cap and rotor button in my 1998 K1500 with 185k miles two weeks ago. Although it was my first time doing this, and it took a while, it went well with the help of an excellent YouTube video showing the whole job being done on a 1999 Suburban. The engine ran great until 2 days ago when it began running rough and check engine light came on. The plug wires I bought (I bought the cheapest set---a mistake) were each approximately 1/2" shorter than the original wires. So, I immediately thought one of the wires may have become loose. I pushed the wire tight on the number 3 receptacle on the distributor and heard a click, so I thought my problem was solved, but truck continued to run very rough an Scan showed misfire in the #4 cylinder, I pulled the #4 plug and it was fouled, so again I thought my problem was solved, but no luck. All other plugs were nice and clean. I pulled the distributor cap and the rotor button did not seem to be in the same position as when I installed it. At installation, I was careful to mark the location and install the rotor button in the same position as instructed in the video (pointing toward the left at #1).
So, needing to get the truck running right, any suggestions on where to turn next would be most appreciated. Thanks for any help you can provide.
Old Jul 8, 2012 | 7:57 AM
shamrock246's Avatar
These engines dont like cheap ignition parts was that click or cracking plastic?the rotor rotates inside the cap the engine just stopped at a different positon thats why the rotor was pointing at a different spot if thats what you ment,i had problems with a aftermarket cap and rotor when it would rain i went with all AC/DELCO ignition parts and have had no problems yet, if you cant find it locally summit racing or amazon sells it just did a quick check you can get everything on amazon for about $82 plus shipping except plugs
Old Jul 8, 2012 | 4:49 PM
kevinkpk's Avatar
You got crap in the injector. Take an extension with it running and pop the injector with it behind a hammer. Lightly. Should say on #4
gosman
May 30, 2012 11:02 AM
RobertShumaker
Astro
Nov 2, 2011 3:10 PM
The Beast
Sep 30, 2011 10:15 AM
furypilot
Aug 18, 2011 3:49 PM
jaymaynard
Aug 27, 2010 7:45 PM
