2000 S10 misfire
2000 S10 misfire
I have a 2000 chevy s10 4.3 the injectors went on it and I replaced them with the conversion kit also replace the cap and rotor, vehicle now starts and ran, however it now misfires on mostly 3 and 4, it will start and idle fine and at first it runs normal even under higher rpm, however after a short bit it will start to misfire. the only codes i have is random misfire. does anyone have an ideas aboutwhereto go with this?
RE: 2000 S10 misfire
the truck went stop running going down the road like no fuel, the fix was the injectors, i just did that while i was at it, it was not a problem befor do you think the wires and plugs would really have an issue even though they were fine befor
and then the problem may go away for a while, but when it returns let me know how you get it fixed. I've been dealing with a 98 blazer for 2yrs, few thousand dollars, and mechanics that have changed everything except fuel pressure reg. and pump so far. I can't wait till someone figures this out.
buddyleno
March 31st, 2017 8:13 AM
halverson82
June 19th, 2011 9:51 AM
