S-10 & Blazer 1982-2005
2000 S10 Wired AC ON on Defog
Old Nov 7, 2009 | 1:21 AM
itsmacintosh's Avatar
Unhappy 2000 S10 Wired AC ON on Defog
My AC runs when i have my Windshield Defoger seting on so I cant run it for then a few mins before it frezzes the ac out. Umm How can i fix this. And on a side note what is the engine supposed to be idleing at when the ac is on mine is at 1200 *850 off*
Old Nov 7, 2009 | 7:25 PM
rubrhammer's Avatar
Your A/C is supposed to run on defog. When the ambient temp is below 35deg F it won't though. You just need to turn your temp setting higher. This is done to remove moisture from the air that you are blowing on th windshield. Kind of like a dehumidifier if you will.
Bob
Old Nov 7, 2009 | 9:27 PM
MDTAHOE's Avatar
Professional Mechanic
You idle speed should be about the same with the ac on. The IAC is supposed to compensate for the extra load to keep the idle the same.
Old Nov 8, 2009 | 2:58 AM
Bob
Orly Thats odd? Never had a car or truck do that before? So it will turn of at 35 deg f right and if it doesnt?
Old Nov 8, 2009 | 12:26 PM
MDTAHOE's Avatar
Every car does that.
Old Nov 8, 2009 | 3:53 PM
Car that have or had that dont
1998 Chevy s10 *still have*
1994 Chevy s10 *still have*
1991 Chevy s10 *still have*
1987 Chevy s10 *still have*
1993 Chevy s10 Blazer *stolen*
1995 Chevy Silverado 1500 *sold*
1999 Chevy Tahoe *sold*
2000 buick lesaber limited *just sold to buy my 2000 S10*
They dont do it and i checked. -_- Maby there messed up...... Hope not
I like s10s by the way.
Old Nov 8, 2009 | 7:18 PM
MDTAHOE's Avatar
Does the ac work on all of them?
Old Nov 9, 2009 | 8:10 AM
Deteoni's Avatar
The compressor is also set up to cycle on/off with the defrost because the system needs to be run periodically to keep the seals and o-rings lubricated. But who's going to run the a/c system when it's cold? So they tied it to a function they know you will use in cold weather..defrost
Old Nov 9, 2009 | 8:39 AM
Yes as far as i know
Yeah mine in my 2000 is not cycleing on and off but the system is new? Yeah idk i live in texas i really dont get that cold the only reason why it bothers me is when the ac is on it idels at 1000-1200 rpm its wired?
jon.wheelz
Aug 26, 2011 12:48 PM
ls00impala707
Jul 2, 2011 3:18 AM
d1nonly34
May 9, 2009 9:31 AM
thezanejt
May 8, 2009 4:09 PM
06impalaltz
Feb 10, 2009 3:19 PM
