2001 blazer not reading codes, cant pass emissions check!!!
Hello,
I am new to this forum, i am a Porsche guy. But my uncle owns a 2001 Chevy Blazer. The check engine light came on, took it to advance, they said it had multiple Mis-Fire's. So from what i read it is usually the spider injector for this weird thing called CFI :icon_goofygrin: So i replaced the CFI with the new MFI spider which actually has individual injectors rather than the poppet valves.
So i got that done, started right up, drove it about 50 miles, then the check engine light came back on, and you could tell it was still mis-firing by the way it idled, not a bad mis-fire but still a misfire. So my uncle took it back up to advance, had them check it, scanner said it was Cylinder 1 misfire. Went home took out cylinder 1 spark plug, which was broke, replaced it, check engine light was still on. Then i took it back, then the scanner read a Multiple cylinder mis-fire again. My uncle had them clear the codes. but instead of the sensors resetting nothing is reading. We hooked it up to a more powerful scanner ( a snap-on scanner 15K). It says that nothing is reading, or resetting. We went through the drive cycles, many times. Still nothing.
Thank's in advance for the help.
