2001 S10 Blazer bushing problem
I need to find the right moog bushing to replace the rear leaf spring front. I went to the local auto parts place and the numbers they have show the same size for the rear as the front, but this is wrong as the front is far larger than the two in the rear section. Anyone got the correct part number. I am in a bind as the blazer is sitting on jacks until I can fix this....
Ok, update. I found the bushings from a website SDTrucksprings.com The front takes a 2" Dia X 3" long and the rear leaf takes a 1 11/16" Dia X 3" Bushing. Beats the dealer as they only want to sell you the entire spring with bushings. Hope this helps someone.
