S-10 & Blazer 1982-2005
2001 S10 V6 4.3L battery drain
Old Nov 13, 2019 | 9:35 PM
R Perry's Avatar
Default 2001 S10 V6 4.3L battery drain
Gauges start reading after truck is off. Garage replaced ignition switch. But that didn’t help. I have killed one battery and it has been draining the new battery.
Old Nov 14, 2019 | 2:39 PM
oilcanhenry's Avatar
Something is allowing power to your gauges. As a quick cheap fix you could install one of those cut off switches on the battery until the problem is solved. Sometimes alternators have been the culprit.
Old Nov 15, 2019 | 2:27 PM
R Perry's Avatar
Default S10 battery drain
THANKS! Oilcanhenry that’s a great temporary fix. The alternator checked out ok. Thanks again.
Old Dec 20, 2019 | 1:59 AM
Ricardo57's Avatar
2 suggestions-determine which fuse is controlling the circuit by removing fuses until the circuit is opened, if you can isolate the circuit look for shorts in that section of wiring. A simple "idiot light" current test probe can help you identify the wires carrying current to isolate the bad wiring.
traderbobs
Jun 5, 2018 10:46 AM
Scotiapilot
Mar 15, 2016 12:35 PM
jlockler
Jul 7, 2013 6:41 PM
Blue Burb
Jul 22, 2012 8:40 PM
silverado99
Jan 21, 2008 12:35 PM
