S-10 & Blazer 1982-2005
2003 s10 2.2L vary slow crank
Old Dec 11, 2021 | 4:21 PM
ex563's Avatar
Default 2003 s10 2.2L vary slow crank
So I got a s10 rather cheep. seen it was leaking fuel from the tank,(it was just a Hose) I replace the hose and got a new battery for it. Go to start it and it has a vary vary slow crank? Any idea on that it could be?
Old Dec 12, 2021 | 7:58 AM
Welcome from Florida. Since the battery is new, check your battery cables at both ends for loose connections and corrosion. If the cables are good and tight, the next thing to check is the starter itself.
Old Dec 14, 2021 | 7:59 PM
12three's Avatar
i dont know about the fuel system on a 2.2L but on a 4.3L I would replace the fuel filter regardless given how finicky the fuel system on them are...
Old Jan 1, 2022 | 10:08 AM
hogbiker's Avatar
good idea on the filter, however, doesnt explain an "under cranking" condition...I'd start w/the COMPLETE check of the batt terminals AND the leads-from end to end
Old Jan 1, 2022 | 10:15 AM
make sure the new battery is fully charged...if it sat for months at the parts store and not put on a battery maintainer....it can have a low state of charge.
turn the engine over with a breaker bar and socket on the crank pulley bolt. if it hard to turn over by hand you have a engine problem.
check the battery cables by doing voltage drops across the cables when cranking. should have less that 0.3V on the postive and 0.2V on the negative.
if the battery, cables, connections and it turns over easy....may be a bad starter. check the starter draw. 35 amps per cylinder is normal at room temp.
nocando 1945
Dec 23, 2018 2:10 PM
lewkamp@yahoo.com
Oct 22, 2018 8:16 PM
chevytrucks4life
Dec 11, 2014 8:43 AM
mastermosley
Dec 20, 2007 12:11 PM
bowler1013
Jul 12, 2007 6:47 PM
