S-10 & Blazer 1982-2005
2003 S10 instrument panel problem
Old Dec 10, 2018 | 10:43 AM
Gail Sarette's Avatar
Default 2003 S10 instrument panel problem
I changed my thermostat and now the speedometer, tach, fuel and temp gauges do not work. The battery and oil ones are still working. I checked for burnt fuses and there are none. It was a simple thermostat change that took about 20 minutes so what now? Any help is appreciated.
Old Dec 10, 2018 | 11:45 AM
SBchevyfan's Avatar
Did you disconnect the battery while changing out the thermostat?
Old Dec 10, 2018 | 12:09 PM
no i did not disconnect
Old Dec 11, 2018 | 12:33 PM
SBchevyfan's Avatar
Try disconnecting the positive battery cable for about 10 minutes then reconnect it and see if it resets your gauges.
