S-10 & Blazer 1982-2005
2004 S-10 4.3L V6 over heating
Old Jul 26, 2010 | 4:36 PM
Dcloser6's Avatar
Default 2004 S-10 4.3L V6 over heating
It just started and I had to turn on the heat full blast to prevent it from red lining. Water level seemed ok, but not sure if it was cycling thru or not.
I know it could be the thermostat and wonder how hard that is to replace.
Also are there any other things it could be?
Appreciate any help.
Old Jul 31, 2010 | 11:53 PM
stock s10's Avatar
T stat isn't that hard to replace easy way to check is to let it run and get up to operating temp. then check your upper and lower hoses for a temp. difference. If it is your T-stat than all you need to do is let it cool down then pop the t-stat housing(What your upper hose connects onto the intake to) off and replace, refill coolant and burp system. Only other things I can think it might be is maybe clogged radiator or water pump that took a S**t
thisnthat
Nov 20, 2012 11:36 AM
vanhan316
Aug 3, 2007 9:27 PM
m00n
Apr 7, 2007 8:44 PM
jsshark1
May 31, 2006 4:49 PM
