S-10 & Blazer 1982-2005
3.08 rearend
Old Sep 1, 2015 | 6:17 AM
xkmhx's Avatar
Default 3.08 rearend
Can I use a 3.08 4wd rear end out of a s10 for my 4wd s10 blazer?
Old Sep 7, 2015 | 12:23 AM
toocute350's Avatar
Yes you can.But usually a 4wd drive will have a 3.42 or better in it.A 3.08 is usually a bigger gear that normally gets better gas mileage..Or AKA a highway gear. 3.42 gear cranks up the R.P.M.`S at highway speeds.3.08 decreases the rpm`s at highway speeds.The higher the number..The faster your motor spins on take off`s and highway driving.
Old Sep 15, 2015 | 6:30 PM
papacarn's Avatar
Unhappy matched differentals
You would have to change both differentials in a 4 wheel drive or they would be fighting each other when 4 wheel was engaged. The front differential is usually about 1 point faster then the rear to give steering control. example: 83 S-10 4/4 front diff is 411:1 while the rear diff ratio is 410:1. So make sure the ratio for your S-10 matches the ratio in your S-10 Blazer before you switch
JR Samples
Sep 15, 2008 8:25 PM
chevyman1978
May 31, 2008 6:33 AM
SimpleMan57
Mar 16, 2008 8:43 PM
joe200120012001
Aug 22, 2007 7:35 PM
BMDAKK
Mar 13, 2007 2:55 PM
