S-10 & Blazer 1982-2005
327 s10
Old Jun 29, 2020 | 10:22 AM
Bdawg6995's Avatar
Default 327 s10
Hey guys,so I've decided to build a v8 s10, something I've been wanting to do since I was 16. I just have some questions about the motor.
it's a 1965 327 sbc out of an impala. I have the block, pistons, and crank. Staying stock bore size for now, what sort of intake/ carb setup would you recommend? Truck will be street/ strip
and I can't decide between a th350 or a 400 for the trans.
Old Jun 29, 2020 | 10:42 PM
oilcanhenry's Avatar
I am not an expert in automatic transmissions, so I can't give you any advice on that, but I've overhauled many a carburetor in my time. Stay as far away from the Rochester Quadrajet 4-barrel carburetor as you can! They are nothing but trouble, trust me on that. I'd go with a good Holley carb myself, but the Eldelbrocks (used to be Carter brand, but they got bought out) are also a good choice.
The 327 cubic inch GM engine is a great small block motor, and most of them will blow a 350/5.7 liter motor away, that's how good they are. Back when high-compression motors ruled the roads, only a big-block motor was more powerful. Even the 400 cubic inch GM small block is inferior to the 327 high-compression, closed-chambered head motors for speed and high-performance racing.
harikari
Mar 10, 2017 7:34 PM
burticushurticus
Feb 24, 2010 5:38 PM
Slow-SBCTT-Poke
Oct 1, 2009 6:53 PM
jtchevy05
May 10, 2009 3:05 PM
bikes91
Jan 21, 2008 4:35 PM
