S-10 & Blazer 1982-2005
4.3 Trouble 2003
Old Jun 8, 2012 | 10:09 PM
skyler4321's Avatar
Default 4.3 Trouble 2003
2003 S-10 Extended ZR2 190000 Miles
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
When I got it a year ago it ran just ok and it got 15 MPG. It needed all the maintenance items. Plugs, wires, filters, ect everything was shot. I have had lot of 4.3s ( 10+ ) and this has always made them run great. This made no difference on this truck. The idle is ok but on the lousy side. It almost feels like a miss but has no misfires. Driving feels ok but has poor power. Today I tried to keep up with another S10 4x4 getting on the highway; it was not even close he passed me gained more than 100 feet in 5 seconds. It was just like my truck has the 2.2L. I pulled a 3500# boat with a 2wd 4.3 s10 to the lake and back on about ¾ tank of fuel. This truck burned a whole tank and had to be refueled 30 miles from home. I have made the trip also with a 4.3 2002 Asrto van full of people on much less fuel.
<o></o>
The Cam Retard is -5 @ 1200 RPM and -4 @ 2000
If you listen very carefully you can hear what I think is the balance shaft rattle at 1800RPM while driving uphill. With a stethoscope on the timing cover it sounds good. The engine sounded fine while pulling the boat.
The distributor aligns with the number 6 mark at TDC as it should
It has no misfires and uses almost no oil.
<o></o>
I love the truck but this engine trouble is driving me crazy.
Old Jun 8, 2012 | 11:03 PM
skyler4321's Avatar
I can move the distributor from -6 to -2. It is now at -2
Fuel pressure engine off is 59.5 with 0.5 PSI drop over 5 min.
It is 54 PSI at idle and jumps up as the throttle is cracked.
Adjusting the distributor from -<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com5 to -2</st1:time> has helped. It has much better acceleration. 0 to 60 WOT is 14 seconds. I did not time it before however I would estimate 18-20 seconds. Is it a bad sign that I can not adjust it past -2?
<!-- google_ad_section_end -->
Old Sep 2, 2012 | 1:21 AM
agp3075's Avatar
timing chain or gear?
Old Sep 2, 2012 | 4:50 AM
junkman104's Avatar
Have the exhaust checked for a bad cat or muffler blockage. Does it store any codes?
JadeMushroom
Nov 28, 2014 3:36 PM
Hammer73
May 18, 2014 4:10 PM
dozer157
Sep 8, 2009 7:32 PM
bpc4him
Dec 6, 2008 6:23 PM
BlazerBoy
K5 Blazer
Oct 24, 2005 10:54 PM
