S-10 & Blazer 1982-2005
4x4 not engaging
Old Feb 11, 2015 | 2:30 PM
Natty68's Avatar
Default 4x4 not engaging
98 Blazer with 4.3 (4dr). When I push the button I can here a clicking sound coming from glovebox area but no telltale clunk of transfer case engaging. When driving in 2-Hi all three lights on 4x4 switch sometimes blink. Pretty sure will only make 'clicking' sound if I try to engage 4-Hi in neutral. This is older model with 2hi/4hi/4low......no awd option. Any suggestions/info is greatly appreciated.
Old Feb 14, 2015 | 10:06 AM
PtownBubba's Avatar
My son's 2K S-10 Blazer will no engage the front axle.
I replaced the vacuum control switch on trans. case
[little tough to do, I removed front drives shaft to open things up a little ]
The switch was bad, and there was a pinhole or small leak in the vacuum line going to that switch. I replaced the vacuum switch, then took the font right side axle half/shaft out. Then to the gear assembly where things happen.
I had this;
Ordered a gear kit, $65,,, I do not know where the two thrust washers are suppose to go [ #5 in pic ]. Any ideas if I need ,,, or where the two large spacers go ?
YouTube help;
Old Feb 27, 2015 | 6:54 PM
kevykev66's Avatar
Natty, I was having issues with my 03 S10 not wanting to go into 4wd. I checked the control module behind the passenger side kick board, applied some dielectric grease to the connections and like magic, no more issues. It's the easiest possible fix to try before you go any further. good luck.
doubld
Apr 29, 2014 6:30 AM
stevesobel24
Dec 2, 2011 1:10 PM
BYUFanatic
Aug 2, 2008 1:30 PM
holyspatulaboy
Feb 20, 2008 5:26 PM
timdogg1313
Sep 9, 2006 7:01 PM
