S-10 & Blazer 1982-2005
83' Chevy S-10 2.85V6
Old Jun 20, 2007 | 7:36 PM
UghChevy's Avatar
Default 83' Chevy S-10 2.85V6
Hello all, I have a 1986 Chevy S-10 P/u. I have a wiper motor problem, I don’t know any of the wiring about it, and if someone can help it would be a lot of help.
The Problem: The wipers done work at all, no delay nothing, but the motor for the windshield washer fluid will activate.
The Question: Does anyone know what the wiring for the connector harness to the motor is, the Hot's and the Ground's. I already went to the local wrecking yard for 2 different motors and both did not work; I still have my current one that I pulled out of the unit. If someone knows the diagram for the wiring and how it should be so I can check it it would be a LOT of help. Thank you ~Nick.
Old Jun 20, 2007 | 9:43 PM
CrashNburn's Avatar
Default RE: 83' Chevy S-10 2.85V6
if its not your motor. check the switch chevy had crappy wiper motor switches. theres also a small circuit board in the wiper motor that gets damaged. i cant remember off the top of my head, but i think you can get it fixed.
Old Jun 20, 2007 | 9:56 PM
CrashNburn's Avatar
http://aplsweb.com/Wiper-Fix/WiperFix.htm
see if this helps. of not
goto http://www.s10extremist.org
they can help!!!
