S-10 & Blazer 1982-2005
85 blazer s-10 2.8 v6 fuel pump relay?
Old Dec 16, 2010 | 9:40 PM
gameon07's Avatar
Exclamation 85 blazer s-10 2.8 v6 fuel pump relay?
i cant find the fuel pump relay. can anyone tell me were it is? thanks
Old Dec 16, 2010 | 10:42 PM
old dog's Avatar
Default s-10
so yours is fuel injected ?
Old Dec 19, 2010 | 12:43 AM
gameon07's Avatar
Default s-10 blazer
it has a carburetor.
Old Dec 19, 2010 | 8:18 AM
old dog's Avatar
Default 85 v-6
you should have a full mechanical fuel pump bolted to the drivers side of the block . i have a 1985 s-10 with a carburetor and that is were it is , i can see it through the wheel well .you should only have a relay if it has fuel injection and a electric pump in the tank that you could hear run when you turn on the key .
Old Dec 24, 2010 | 3:36 PM
gameon07's Avatar
ok thanks. yea i didn't hear the pump purge so i thought it was the relay, but if i have a full mechanical pump i guess there's no purge to be heard. so how can i check fuel delivery?
Old Dec 24, 2010 | 7:28 PM
old dog's Avatar
Default s10
well if you have any body to help you take the fuel line off at the carb and put a long rubber fuel line on the fuel line long enough to reach a coffie can make shure the the battery is charged up good .hold the hose into the can and turn the engine over at 25-30 second intervuls watch to see if any comes out of the hose ,of corse make sure there is gas in the tank .it may or may not pick up a prime if it's been a while.
if not and you have a air compresser put a nozzel with a rag around it put a little air in the tank to help fill the lines .if all else fails you might have a bad fuel pump .
brerobx
14
Jun 26, 2021 4:36 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
mikee
Aug 26, 2007 10:38 PM
oneflatoniakid
Jun 18, 2007 10:30 AM
