S-10 & Blazer 1982-2005
91 4.3 won't turn over
Old Jan 28, 2010 | 10:16 AM
mnchevy's Avatar
Default 91 4.3 won't turn over
I just bought a 91 4.3 S10 ran good for about an hour drove it home parked it. Started it about 2 hours later to go put gas in it for work in the morning died, it like chugged and spit and sputtered in the driveway has spark and was getting gas but woudn't start left it until morning went out hit the key and started right up drove about 3 blocks started to chug and then died now it won't even turn over all the lights work radio dash lights, turn the key and don't get anything not even clicking,but I don't lose any dash lights or nothing.? Help it is sitting on the side of the road need to get it moved. hopefully something simple. O yeah I have tried to jump it to but I don't think the battery is dead.
Old Jan 28, 2010 | 11:47 AM
gotstylez's Avatar
try to start it from the starter itself bypass everything befor the starter .. that would be a way to tell you if its something before the starter or something with the engine. but this wouldnt explain why it would die after you drive it 3 blocks.. also u might wanna try to call whoever u bought it from and ask if they had problems with it
Old Feb 10, 2010 | 8:14 PM
mnchevy's Avatar
Problem fixed started crapped out on me.
Old May 6, 2010 | 5:41 PM
Texcowboy's Avatar
under your distributor cap is a module replace it its really cheap and started and it go out around same time i had same problem with my 92' easy cheap fix
Old May 6, 2010 | 5:54 PM
Texcowboy's Avatar
ZChevyAK
Nov 13, 2015 6:45 PM
thisnthat
Nov 20, 2012 11:36 AM
Chevrolet Forum News
Sep 25, 2012 8:48 AM
jhl1188
Sep 8, 2007 11:26 AM
DarkAsylum
Nov 20, 2006 11:05 AM
